event structures
hi working on bringing exsiting code in to teststand with out editing the code to much,    the code has a lot of event structers being set off by button change , while i have found away to change the state of the button while the code is running with out pushing the button the event structuer dose not seem to recagnise the change, and dose not do any thing,  i have included a exaple of what im trying to do,
(3,682 Views)
Accepted by topic author davidom912
Local variable will not trigger event structures.
You need to use the "Value (Signalling)" property node.
(3,661 Views)
thanks will give that a try
(3,655 Views)
thanks that worked perfictaly still new to labview
(3,642 Views)
No Problem.
It is worth having a read of the "Caveats and Recommendations when Using Events in LabVIEW" section of the LabVIEW help file.
(3,638 Views)
