how to make acquired values to zero during exection of program
Hi
I need a help from you guys .
I created a small application of Encoder , purpose of which is to increase the count values.
if i have to make zero to the count values ,I have to stop the exection then run again .
Is there any other method by which i can make value of count to zero during execution of program?
Reagrds
nitin
(2,750 Views)
Hi nitin,
what about an additional RESET? input to your "encoder" function?
IF RESET? THEN
   count := 0
ELSE
  do nothing
ENDIF
(2,740 Views)
@Nitin_110051 wrote:
Hi
Reagrds
nitin
A simple boolean and a Select function can take care of this very easily.
(2,726 Views)
