How to identify the CAN hardware connected to the PC
Hi
     Is there any way to identify the CAN devices to the PC via USB port, I am able to see the connected CAN hardware name in the device manager list. Same I would like to read using LabVIEW.
Regars
Visuman
Message 1 of 9
(3,308 Views)
Try the following VI.
In LV version 2010
Message 2 of 9
(3,303 Views)
Thanks for the reply can you send the same in 2009 version I dont have LabVIEW 2010.
Regards
Bharath
Message 3 of 9
(3,301 Views)
Message 4 of 9
(3,298 Views)
The VI is searching for some support files, kindly attach the support files also in 8.5 version.
Message 5 of 9
(3,285 Views)
You will need the
NI System Configuration API
Message 6 of 9
(3,273 Views)
Hi
    Thanks for the reply, code is listing only the NI device. But I would like to see the connected third party devices also which I am seeing in the device manager.
Regards
Visuman
Message 7 of 9
(3,260 Views)
Accepted by visuman
Use the vi in the zip file.
And the "Devcon.exe" will show you the device list.
With this list you may sort out the devices bei searching the string.
Message 8 of 9
(3,252 Views)
Thanks its working.
Regards
Visuman
Message 9 of 9
(3,242 Views)
