How to implement Wait time ERROR Message.
Hi all,
I need to implement a wait time(for example 400ms)
to read Sensor for ON .
if its Not Achive i need to show Error message .
I have implement this in folowing way ..
But i am not happy with this method ..
is this correct method.
I have attached my VI file
(4,403 Views)
Hi is anybody got solution for my question .?
(4,359 Views)
It's good that you are not happy with this. You should checkout the online tutorials. But in the mean time can you describe step-by-step what you want the VI to do?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,358 Views)
Hi Mike,
i need to check the input pin (Sensor) of my arudino  .
and i am waiting for the pin to high  for a specfic time .
if its not achived at the specfic time ,i need to show pop message.
(4,348 Views)
I am asking kind of "TIMEOUT" function ..
(4,344 Views)
Accepted by topic author SaranVenkateshS
You can replace the Count_XL functionality you made by just using the iteration terminal in the bottom left of your while loop.
As for making a timeout, you could use the Elapsed Time express VI to check if a certain amount of time has elapsed and end the loop if your sensor is true or time has elapsed.  There are a lot of ways to do this but the best way will be determined by how you want your application to work.
(4,322 Views)
Hi Jacobson,
Thanks a lot for your reply ..
(4,312 Views)
