How to import dll using command line
I'm trying to automate dll import using Jenkins. So the question is:
is it possible to import dll in Labview using some sort of command line? Right now i have to do it manually by going to Tools>>Import>>Shared library (.dll). Then i have to select dll itself and .h file, wait a little and get my library. Every time dll and .h file changes (which happens with every new revision) process has to be repeated. It would be nice to automate it though. Any thoughs?
Thank you in advance!
www.xinstruments.com - Custom Software for Industrial Automation
www.hdrconverter.com - Picture processing made easy
Message 1 of 1
(2,846 Views)
