Calculat time
Hi
I have control as time string formate time1 =  11:15:32.890 and time2 = 11:15:35.960
I want to subtract time2 from time1 and get total time , in this case it will 3 sec
how can I do that using labview
thanks
(2,994 Views)
Look at the String and Timing palettes. The Date/Time to Seconds functions will convert separate numerical components into a timestamp. Spreadsheet String to Array (with : as separator) and Index Array gets you the components.
There are several other ways as well. Scan from String can probably be used.
Lynn
(2,981 Views)
Assuming ur using period (.) instead comma (,) to separate fractional seconds...  Use scan string function and change the DBL display format :]
(2,967 Views)
