How to import picture to OCR check
I Want to import a folder contain large amount oof photos.
And then using LV7.1 to OCR check.
Now, i can only input 1 phototo ocr check.
How cam I import the folder with photo to check?
Thank You!!
(3,247 Views)
I recommend to put your OCR Check into a For Loop (or a separate VI).
Retrieve the list of photos in your folder and pass that array of paths to the loop.
Guenter
(3,234 Views)
My Folder will have 2 different type picture file (.jpg, .bmp)
how can i run labview  the  prog.  with  auto  select  all the image file(.bmp, .jpg) into OCR Check
Thank you!
(3,176 Views)
Thank you for posting to the NI forums!  Try calling List Folder.vi twice (once for .bmp and once for .jpg) then concatenating the file list arrays.
Maclean G.
Applications Engineering
(3,159 Views)
