How to increase a number by 1 in a loop
Hi this is sligthly more difficult than the title reads i think.
I have a while loop reading the com port to detect a switch being on or off by doing an rs232 loopback
if i get an error its off,  no error on.
what i want to do is increase a number by 1 when the switch is on the off position, but at the moment
the number just constantly increase as the "+1" function is in a loop.  How can i make it only increase
the number once.
The loop needs to constantly run if the switch is on or off
Hope this makes sense,  i have attached a picture of what it does now
I look forward to your suggestions.
Message 1 of 8
(5,134 Views)
You can add a shift register that will remember the last state of the switch. If the last state of the switch was True, but now is False, you can increment your counter.
-Cristian
Message 2 of 8
(5,118 Views)
Accepted by theno1dj
One way is to use a flag.  I change the flag to true as soon as the thing turns on, then false again until the next time it's turned on.
There may be better solutions, but this is the first thing that came to mind.
EDIT: My example is what Cristian said.  Beat me to it.
Message Edited by elset191 on 11-20-2009 08:41 AM
Tim Elsey
Certified LabVIEW Architect
Message 3 of 8
(5,115 Views)
What about the First Call? function (in the Synchronization palette). It lets you do something once then forget it on subsequent calls. Just wire it to a case statement with your incrementor in it.
edit: After re-reading your post I think you need Tim's idea above, not the First Call? function, but just in case you didn't know about it, there it is! Smiley Happy
Message Edited by Broken Arrow on 11-20-2009 08:57 AM
Message Edited by Broken Arrow on 11-20-2009 08:58 AM
Richard
Message 4 of 8
(5,096 Views)
I think he wants it to increment every time the switch is flipped.  Not just the first time.  At least, that's how I understood it.
Tim Elsey
Message 5 of 8
(5,089 Views)
Yep, I was editing while you responded Smiley Happy
Richard
Message 6 of 8
(5,079 Views)
Cheers tim that is exactly what i wanted,
so simple but im struggling this friday afternoon.
Thank you very much
Message 7 of 8
(5,078 Views)
oops too late.
You guys are fast.
An example follows.
Message 8 of 8
(5,058 Views)
