How to increase number of selections displayed from system combo box?
I am populating the string array of a system combo box from my program. I have a lot of elements and would like to display more than the default amount of 7 selections when the drop down is clicked.
I know this can be done easially in MS Access but I don't see a obvious property I can set in the property nodes.
Thanks!
(3,219 Views)
At first glance with the property nodes of the system combo box control, I do not unfortunately think you can change the displayable items after clicking the down arrow to allow more than 7 to be displayed.  This however, is an excellent product suggestion and I highly suggest you request this feature for future versions of LabVIEW.  You can file a product suggestion through the link provided here.
Nadim
Applications Engineering
(3,183 Views)
@Nadim R
Thank you for your response. I will stop looking for the feature! Smiley Happy
I posted the suggestion for improvement as you suggested.
(3,178 Views)
This feature would be nice.  Someone asked me if I could increase the number of dropdown items of a combobox in my GUI just today!  (LV2011)
(2,833 Views)
While you can't control this with the various drop downs in LV, you could either implement the list yourself (as a popup VI) or use an ActiveX/.NET combo box, which presumably will support this.
Also, if you want this to actually be in LV, I would suggest adding it to the idea exchange (search first to see if it isn't already there).
___________________
Try to take over the world!
(2,829 Views)
You can create an xctrl for that.
Define the height yourself.
See attached demo.
George Zou
(2,810 Views)
Cool, at least I know there's a workaround now.  When I have some free time I'm going to look into how easy it is to implement this although I'd rather have it be a property of the native control.
Bruce
(2,792 Views)
