How to increase speed of stepper motor
I have written a program to move stepper motor to clockwise and anticlockwise direction. I wanted to increase the speed of stepper motor which I'm unable to do. Please help me with this. I am attaching the VI.
Message 1 of 9
(3,950 Views)
Hi canzie,
Maybe using a lower value for the wait function inside your FOR loops may help?
- Why do you need to cases for "clockwise" and "anticlockwise"? They only differ in just one bit! (Yes, just one boolean value…)
- Why don't you use AutoCleanup?
Message 2 of 9
(3,948 Views)
I'd say the normal solution is to use the Counter out and simpy set a frequency, then it's very easy to change speed. With your current solution you'll need to change the Wait(s).
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 9
(3,945 Views)
Will you please elaborate it
Message 4 of 9
(3,937 Views)
As reference.
/Y
Qestit Systems
Message 5 of 9
(3,930 Views)
But I am using LINX in that there is no such option of counter frequency.
Message 6 of 9
(3,909 Views)
Then you basically have to change the case to this. Remove the for loop and have it perform the case every X ms.
/Y
Qestit Systems
Message 7 of 9
(3,898 Views)
Sorry I didn't understand.
Message 8 of 9
(3,889 Views)
Instead of having a For loop run 100 times, remove the for loop and let the whole program and Case run again and again, and switch the LED each time. The previous picture is the removed for loop with a feedback node for switching.
/Y
Qestit Systems
Message 9 of 9
(3,879 Views)
