How to indicate an Event based producer-consumer structure is running or waiting for an event to process
Hi I have an event based producer-consumer loop . Inside the producer loop I have the event structure and then I queue the events and response to the events using a case structure in my producer loop.
The problem I have is . I have lots of controls on my front panel and when I click on one control I don't know how long does it takes to process the evennt-queue the message and process that specific case in my producer loop
How and where can I use an indicator to show there is no event ( green light ) and we are waiting for an event
and red indicator to show something is processing
(3,016 Views)
Hi tintin,
sounds you want to use the TimeOut event to indicate you're waiting for new events…
(2,999 Views)
Could you please help me with this. How can I add this time out event?
(2,987 Views)
Hi tintin,
add an event to your event structure. Select Application->TimeOut for the event source…
(2,982 Views)
I don't know your setup so I don't know if this is applicable but you could setup a request for the consumer to do something, and then have the consumer send a reply back to the producer.  Then you can have notification that the operation was processed.
(2,969 Views)
@GerdW wrote:
Hi tintin,
I wouldn't necessarilly go there.....
This little piece of work might have just what the Dr. ordered to inspect events that are pending.
2013 and later.  The subvi is a undocumented piece of the event inspector window.
(2,966 Views)
