04-22-2014 09:19 AM - edited 04-22-2014 09:20 AM
Hi I have an event based producer-consumer loop . Inside the producer loop I have the event structure and then I queue the events and response to the events using a case structure in my producer loop.
The problem I have is . I have lots of controls on my front panel and when I click on one control I don't know how long does it takes to process the evennt-queue the message and process that specific case in my producer loop
How and where can I use an indicator to show there is no event ( green light ) and we are waiting for an event
and red indicator to show something is processing
04-22-2014 09:45 AM
04-22-2014 10:03 AM
Could you please help me with this. How can I add this time out event?
04-22-2014 10:05 AM
04-22-2014 10:37 AM
I don't know your setup so I don't know if this is applicable but you could setup a request for the consumer to do something, and then have the consumer send a reply back to the producer. Then you can have notification that the operation was processed.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
04-22-2014 10:45 AM
@GerdW wrote:
Hi tintin,
sounds you want to use the TimeOut event to indicate you're waiting for new events…
I wouldn't necessarilly go there.....
This little piece of work might have just what the Dr. ordered to inspect events that are pending.
2013 and later. The subvi is a undocumented piece of the event inspector window.
