How to install unsupported (obsolete) toolkits/modules in newer LV versions?
Installers of LV toolkits/modules do not permit installation in newer LV environments. I don't know if that is necessary, but I am quite positive most of them would actually work 100%. If this "feature" cannot be revised, is it possible to obtain a workarround procedure (file/folder specification) for manual installation?
I am specifically interested in installing the LV 2012 ARM Module in LV 2014. Even if I find time and mashine to install LV2012, than the ARM module, I am not sure I would be able to completely "move/copy" the ARM installation into the corresponding folder structure of the LV 2014.
So, is there an explicit  manual installation procedure?
Thanks in advance,
(3,446 Views)
I have no knowledge of the specific toolbox you are asking about, but the ability to move old toolboxes to new LabVIEW depends (for the most part) on things like hardware or DLL compatibilities.
If a toolbox is written in 100% LabVIEW, you should be able to use it with no problem. Earlier this year I needed to access a device via telnet. Unfortunately, NI had dropped the telnet VIs from the internet toolkit is 2012. I was able to copy the old telnet VIs to my 2014 installation, and they worked fine.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,424 Views)
Considering that that toolkit is a compiler, I do not think you are going to get it to work.
GCentral
(3,373 Views)
Hello Crossrutz,
Thanks for responding. I agree it is a (pre)compiler but the true ARM compilation is done by the uKeil external compiler...
Are you positive it will not work in LV2014?
(3,356 Views)
No, we aren't sure -- which is sort of the point. It all depends on how it was written and if there are any dependences.
You need to try it.
Mike...
LabVIEW Champion
(3,339 Views)
