update my scale
I would like to update my scale x this way:
if x is between 1 and 9 so increment by 1
if x is between 10 and 90 so increment by 10 each time
if x is between 100 and 900 so increment by 100 each time, and so on
I thought to implement a case structure and test the variable x, but it will over burden my program
Can anyone help me please
Thank you in advance
My best regards
K.Nadia
(3,512 Views)
How would a case structure over burden your application?  If that overburdens your application, you have a lot more issues than this.  A ranged case structure would be the way to handle your scale problem.
(3,508 Views)
I have other tests to do in my code, and what I wrote in my first message is just a part of my code
(3,500 Views)
I'm not sure what you mean by updating your scale x, but it's pretty simple to go from 'x' to your increment using 10^(floor(log_10(x))
(3,475 Views)
Here is a simple function that converts an integer into an "increment" (so 1-9 returns 1, 10-99 returns 10, etc.).  I added a test for 0 and negative numbers, treating them as though they were 1, but you could modify this to better suit your needs.
Bob Schor
(3,474 Views)
