How to interface Princeton instruments spectrometer
I need to know which interface is available to communicate the instrument through. I need to design an application to acquire the spectra.
The problem is there no interface available at all.
Need help!
(4,973 Views)
What is the model number of the instrument?
Didn't you answer your own question?  If there is no interface available, then what are you asking for?
(4,948 Views)
I've used one of their SpectraPro models, and there's an ActiveX automation interface that can talk to the software that controls it.
If I remember right I think I had to contact their support department directly to get a copy of their software that worked with Windows 7 and ActiveX under LabVIEW.  It might not be something you can just download.
(4,895 Views)
I am using WinSpec 32 2.6.24.0 version and trying to communicated it through labVIEW using Active X control. Earlier I Could communicated using the Active X in window XP but I not able to achieve the same task in windows 7. Please help me with this problem !
(4,835 Views)
(4,832 Views)
Sounds like you should be talking to Princeton Instruments not us.
(4,826 Views)
Talk to Princeton Instruments.
Don't post the same thing twice and waste people's time.
(4,826 Views)
