How to interface Princeton instruments spectrometer
I need to know which interface is available to communicate the instrument through. I need to design an application to acquire the spectra.
The problem is there no interface available at all.
Need help!
Message 1 of 8
(6,305 Views)
What is the model number of the instrument?
Didn't you answer your own question?  If there is no interface available, then what are you asking for?
Message 2 of 8
(6,280 Views)
I've used one of their SpectraPro models, and there's an ActiveX automation interface that can talk to the software that controls it.
If I remember right I think I had to contact their support department directly to get a copy of their software that worked with Windows 7 and ActiveX under LabVIEW.  It might not be something you can just download.
Message 3 of 8
(6,227 Views)
I am using WinSpec 32 2.6.24.0 version and trying to communicated it through labVIEW using Active X control. Earlier I Could communicated using the Active X in window XP but I not able to achieve the same task in windows 7. Please help me with this problem !
Message 4 of 8
(6,167 Views)
Message 5 of 8
(6,164 Views)
Sounds like you should be talking to Princeton Instruments not us.
Message 6 of 8
(6,158 Views)
Talk to Princeton Instruments.
Don't post the same thing twice and waste people's time.
Message 7 of 8
(6,158 Views)
May I ask you to share me the WinX32 ISO or CD-ROM content please ?
Thanks in advance
Regards.
Message 8 of 8
(1,086 Views)
