How to judge the order of a program
(2,891 Views)
Your question is pretty meaningless. Please provide some details. You are not being charged by the word here.
(2,882 Views)
Dataflow.
(2,866 Views)
Do you know, what Dataflow is? Order of execution of a LabVIEW program is based on dataflow.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,857 Views)
If there are no data dependencies, then you can't tell what will run where.  A function only runs once it has data from all of its inputs and only outputs its data once the entire function is complete.
Run your VIs with highlight execution turned on and it will help a lot to see what is happening.  Note that it will slow your program down a lot.  But it is a great learning tool when trying to figure out data flow.
(2,834 Views)
