‎04-08-2014 02:43 AM
‎04-08-2014 02:53 AM
‎04-08-2014 04:25 AM
Dataflow.
‎04-08-2014 05:01 AM
‎04-08-2014 06:53 AM
If there are no data dependencies, then you can't tell what will run where. A function only runs once it has data from all of its inputs and only outputs its data once the entire function is complete.
Run your VIs with highlight execution turned on and it will help a lot to see what is happening. Note that it will slow your program down a lot. But it is a great learning tool when trying to figure out data flow.
