How to know the device number of USB daq
There are 2 devices, and user may plug in them to different port each time.
But the program is using the same device string and may have error.
Can they auto detect and generate the device string, thanks.
(3,010 Views)
Accepted by alex.
Is it something similar like this (help) you need? If so please go through the link from Andrew's post (2nd one). Post if still you need something else.
Mathan
(2,997 Views)
Thanks, after detection, may i know how to convert a text string 'Dev1/ai0:2' to the task string.
Thanks.
(2,984 Views)
Just simply wire this string to physical channel terminal should be fine.
(2,958 Views)
