How to know the device number of USB daq
There are 2 devices, and user may plug in them to different port each time.
But the program is using the same device string and may have error.
Can they auto detect and generate the device string, thanks.
(3,005 Views)
Accepted by topic author alex.
Is it something similar like this (help) you need? If so please go through the link from Andrew's post (2nd one). Post if still you need something else.
Mathan
(2,992 Views)
Thanks, after detection, may i know how to convert a text string 'Dev1/ai0:2' to the task string.
Thanks.
(2,979 Views)
Just simply wire this string to physical channel terminal should be fine.
(2,953 Views)
