How to know this file or folder path : LabVIEW
how to we know "D:\Archive\Desktop\Robot Control Project\example.xx " file or folder path. I need to know exactly whether it is a file or a folder
(2,239 Views)
Accepted by Petros_Baghalyan
Check in the File IO->Advanced palette.
File/Directory Info function gives you an indication if the path is pointing to a directory or file (if it is valid and exists, otherwise you get an according error).
Rolf Kalbermatter  My Blog
(2,219 Views)
Thank you!
(2,164 Views)
