How to limit the slope of a signal
   I am trying to limit the slope of my speed control reference signal, say I want to change from 100rpm to 200rpm, I don't want it to step from 100 to 200 (which is what the code is doing now), I hope it can change gradually with a changeable slope. Could anyone help me on this ? Thank you very much.
(3,823 Views)
There are many ways to do this, here is one possibility.
(3,797 Views)
Thank you for your reply. But I can't open your file since I am using a labview 14.0.2. Could you do a screen shot maybe for your diagram?
(3,781 Views)
Accepted by yingxiong10
(3,752 Views)
Hi ying,
see "PID Output Rate Limiter" function…
(Despite its name you can also use it for input signals! :D)
(3,737 Views)
Thank you very much, now I see it.
(3,713 Views)
Thanks GerdW, this is a good suggestion.
(3,709 Views)
