How to limit x to be > y always in x+y
Hello:
In the following simple vi, how do I limit the value of x to always be greater than y?
For instance, if I set y = 10 then x cannot be set to a value less than 10. The values for x and y should remain changeable.
Thanks.
Alfredo
(3,526 Views)
Accepted by topic author AlfredoT
Use the In Range and Coerce function.  Set the lower limit to Y, infinity for upper limit, and wire the coerced output as X.
- tbob
Inventor of the WORM Global
(3,524 Views)
Thanks a bunch!
Now for a related question: I see that the function you suggested has a true/false output, perhaps I can use it for the following.
If I set x to be less than y (say x = 5 and y = 10) and I would like the value of x to not be allowed to be 5 but go straight to y if this is the case (o that x automatically sets to y when x<y), how would I accomplish this? Thanks.
Alfredo
(3,512 Views)
That is exactly what the coerced output does.  It will set the input (x) to either the high limit or the low limit (Y).  In this case, x is lower than the low limit, so the coerced output will be equal to the lower limit.  In whatever code you use X and Y as inputs, use the coerced output instead of X.  No additional code needed.
My Labview is down, waiting for a license, so I cannot give you an example.  I hope this is clear enough.
- tbob
(3,506 Views)
I understand what you mean because I have tested it. Thank you.
What I meant was something slightly different: I would like the value of x on the display to change from the value < y to y. I understand that the coerced output will be as such but the displayed x remains whatever value < y I had set it to.
Alfredo
(3,494 Views)
Create a local variable for the X control (right click on control and select create - local variable).  Wire the coerced outptut to the local variable.  If you get a broken wire, right click on the local variable and select Change to Write.
- tbob
(3,471 Views)
Perfect!
Thank you. I wish I had thought of that.
Alfredo
(3,468 Views)
