How to link two controls?
I'm trying to link two controls together, a slider and a numeric, so that if I change the value of one control, the other will also show the new value.
Does anyone knows how to do that? Is that even possible?
Thank you for your help
Message 1 of 15
(7,002 Views)
Accepted by Albany
Right click on your slider.  In the menu go to Visibile Items->Digital Display.
Message 2 of 15
(6,996 Views)
rt click control,create local....connect other "control"
Message 3 of 15
(6,980 Views)
Hi apok,
what do you do to also modify "slide" when "numeric" is changed?
Using the digital display of the slide is much more easier - and fail safe…
Message 4 of 15
(6,975 Views)
@GerdW wrote:
Hi apok,
the OP asked for 2 controls linked?....
Message 5 of 15
(6,972 Views)
Hi apok,
atleast exactly this is the topic of the thread: "How to link two controls?"
Message 6 of 15
(6,969 Views)
i would use an event case for the 2 controls...
Message 7 of 15
(6,953 Views)
Hi apok,
so you would through even more code for something that already is available in the control itself?
That behaviour is called "Rube-Goldberg"… 😄
Message 8 of 15
(6,944 Views)
A slider and its digital display are two linked controls, exactly as requested. Tim's answer is correct and appropriate. No code needed. 🙂
You can "link" as many controls as you want this way, have a look at this old example with eight linked controls (and a single terminal!). (posted here)
Message 9 of 15
(6,917 Views)
That's different.  Usually Christian shows me yet another, more efficient way, to code something.  Well, I guess you can't get more efficient than no code.Smiley Tongue
Message 10 of 15
(6,900 Views)
