How to link two controls?
@crossrulz wrote:
@altenbach wrote:
Tim's answer is correct and appropriate. No code needed. 🙂
That's different.  Usually Christian shows me yet another, more efficient way, to code something.  Well, I guess you can't get more efficient than no code.Smiley Tongue
Well, I added a link to one of my examples that has the same amount of code, but eight controls. This is more efficient "per control". 😄
Message 11 of 15
(986 Views)
@altenbach wrote:
A slider and its digital display are two linked controls, exactly as requested. Tim's answer is correct and appropriate. No code needed. 🙂
You can "link" as many controls as you want this way, have a look at this old example with eight linked controls (and a single terminal!). (posted here)
how is this done? does it have to do with type def...advance/customize mode
Message 12 of 15
(980 Views)
apok wrote: how is this done? does it have to do with type def...copy and paste
No. It is just a control customization. In the control editor, you can replace the digital display of a slide with another slide, which again has a digital control that you can replace with a nother control that has a digital control, and so on.
Message 13 of 15
(964 Views)
nice....
Message 14 of 15
(961 Views)
Wow, that was simple!
Thanks crossrulz for the quick answer and thanks altenbach for the indented controls example, that's a pretty neat trick.
Message 15 of 15
(907 Views)
