How to load Windows "On-Screen Keyboard" application using LabVIEW
      Whether somebody can tell me how to load windows "On-Screen Keyboard" application using LabVIEW.
Bharath
Message 1 of 28
(12,461 Views)
Use system exec.vi for this.
Bijay
Message 2 of 28
(12,456 Views)
Hi Visuman,
As Vijay already told that you can enable on screen keyboard using System Exec function under connectivity --> Libraries and executables --> System Exec.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
Message 3 of 28
(12,452 Views)
    Thanks for the reply I tried with "System Exec" function I am getting an error - Could not start On-screen Keyboard
Bharath
Message 4 of 28
(12,444 Views)
What is the OS version??
Message 5 of 28
(12,439 Views)
Windows 7
Message 6 of 28
(12,433 Views)
I guess yours is 64-bit OS.
Because i am facing the same problem. But the same code is working fine on other PC having 32bit- OS Windows 7
Message 7 of 28
(12,430 Views)
Microsoft Discussion
________________________________________________________________________________________________________________________________________
This is an issue with 64-bit OS, it affects any 64-bit version of Windows.
Basically you are calling osk.exe, but your program you are calling it from is a 32-bit app. Windows won't allow you to call a 64-bit OSK.exe from your program. The comments appear to miss your point here, anyone can start osk.exe from Run, but call it from within a 32-bit application won't work in 64-bit Windows.
Ideally Microsoft should include a 32-bit version of OSK.exe in the system folder and allow us to use it, if being called from a 32-bit application.
Same i try on my windows 7 professional PC with 64 Bit and its working fine here.....
Check in c:\Windows\System32\osk.exe available or not.......
Thanks and Regards
Message 8 of 28
(12,426 Views)
Hi Himanshu,
Osk.exe is present under the path c:\Windows\System32
but still am not able to run using LV.
Bijay
Message 9 of 28
(12,419 Views)
 This should work. Specify the whole path.
 cheers olli
Message 10 of 28
(12,411 Views)
