How to load Windows "On-Screen Keyboard" application using LabVIEW
     As suugesteed by you I gave the full path I am getting a error - Unable to open osk.exe, kindly see the attachment.
Bharath
Message 11 of 28
(5,786 Views)
Hi visuman,
that error message is generated either by Windows or by OSK.exe as can be seen by its text. If the osk.exe wouldn't be found the text would be different!
OSK is found, but can't be started - that's quite a different error message!
I suspect it's some kind of access right problems...
Message 12 of 28
(5,778 Views)
HI GerdW,
Yes, its unable to start the exe. I have Admin privileges still unable to access OSK from LV.
But in another PC, i am able to do it.
Am just curious to know ,why its not happening in my laptop.
Bijay
CLD
Message 13 of 28
(5,770 Views)
it seem to be an issue with access rights. if i use a different useraccount it won't work for me as well.
but interestingly it works out of the temp directory
C:\Users\username\AppData\Local\Microsoft\Windows\Temporary Internet Files\keyboard.vi
so i figure a batchfile with runas should hopefully do the trick. i will give it a try
Message 14 of 28
(5,766 Views)
Give this a try hopefully it works for you
Message 15 of 28
(5,761 Views)
Hi Ofahed,
Tried all those cmds Smiley Sad
Bijay
CLD
Message 16 of 28
(5,770 Views)
Hi Bijay
yea i see your troubles and i bet you have tried all different prossible ways.
this might be not the best solution but since system32 either require adminrights to call osk. you either have to create a batch or vbs ... or whatever to call osk.exe with adminrights.
An different approve would be to create a copy of the file C:\Windows\System32\osk.exe in your project and call this one, you should have the rights to call this file (osk.exe)
To test it i copied the osk.exe on my desktop. This might be an option
Message 17 of 28
(5,765 Views)
I copied osk.exe to desktop and gave the path as mentioned but still can't access from LV.
But really its a good learning for me. Smiley Happy
I hope Visuman gets his issue resolved and post the solution soon Smiley Very Happy
BIjay
CLD
Message 18 of 28
(5,757 Views)
haha ok, sorry, but keep on trying Smiley Wink
still the same error?
Message 19 of 28
(5,754 Views)
Hi all,
          Atlast it happened, as said it was access problem. I tried with a computer which has admin privillege and it works.
Thanks for every one.
Bharath
Message 20 of 28
(5,741 Views)
