How to lock the front panel?
HI,
I know how to eliminate the scroll bar of a text box, but how do I lock the scroll bar of a VI in order to have loaded the same way every time it is called?
Thank you
Rafi
(3,963 Views)
Hi Rafi,
you can find this property using a vi reference with property node in : Front Panel -> window area -> scrollbar!
Hope it helps.
Mike
Message Edited by MikeS81 on 11-25-2008 09:10 AM
(3,957 Views)
Also right click on the vi's scrollbar (front panel), and see what happens.
(3,938 Views)
Accepted by Rafi2003
Hi Pnt and thanks..
Yes it works.  But how do I set it up again after I have removed it?
(3,909 Views)
Hi Mike,
Although Pnt answer is working, I still would like to check out your suggestion.  What exactly you mean by window area.  If I click on the VI window area I get the controls palette. Did I misunderstood you?
Rafi
(3,907 Views)
(3,901 Views)
Hi Rafi,
what i described was the way to hide the scrollbar from inside your vi with property nodes.
Mike
(3,898 Views)
