How to lock the front panel?
HI,
I know how to eliminate the scroll bar of a text box, but how do I lock the scroll bar of a VI in order to have loaded the same way every time it is called?
Thank you
Rafi
(4,707 Views)
Hi Rafi,
you can find this property using a vi reference with property node in : Front Panel -> window area -> scrollbar!
Hope it helps.
Mike
Message Edited by MikeS81 on 11-25-2008 09:10 AM
(4,701 Views)
Also right click on the vi's scrollbar (front panel), and see what happens.
(4,682 Views)
Accepted by topic author Rafi2003
Hi Pnt and thanks..
Yes it works.  But how do I set it up again after I have removed it?
(4,653 Views)
Hi Mike,
Although Pnt answer is working, I still would like to check out your suggestion.  What exactly you mean by window area.  If I click on the VI window area I get the controls palette. Did I misunderstood you?
Rafi
(4,651 Views)
(4,645 Views)
Hi Rafi,
what i described was the way to hide the scrollbar from inside your vi with property nodes.
Mike
(4,642 Views)
