How to make VI with timestamp array input
I am making a sub-VI for a program and I need to have a double array, a boolean, and a time stamp array as an input. I can't find a way to mark the input with a timestamp array indicator though. My only choices seem to be double and void. Is there any way I can do this?
(3,388 Views)
Accepted by topic author nc61
You have to put an empty Array frame on your front pannel and then move a Timestamp control into it.
(3,378 Views)
You make an array of timestamps the same way you make any other array: Drop a timestamp onto a void array.
(3,375 Views)
