Which LabVIEW 2012 Installer disc has System Configuration 5.3.3 on it?
I am trying to build an installer here and under additional installers I selected to install MAX 5.3.3 - the installer builder is asking me to locate the installer for System Configuration 5.3.3 but I can not locate the source installer.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
Message 1 of 9
(4,048 Views)
Device Drivers\Products\MAX\max.msi
Message 2 of 9
(4,044 Views)
Hmm
I am told to locate "NI System Configuration 5.3.3" and when I supply the path to x:\Products\MAX I am told:
"This location does not contain a valid installer"
This process is very annoying!
Message 3 of 9
(4,037 Views)
There are also some folders names starting with NISysCfg in Device Drivers\Products\.  Have you tried these?
Message 4 of 9
(4,028 Views)
download is here
 Sorry I took you in the wrong location
Message 5 of 9
(4,017 Views)
Accepted by topic author RVallieu
I had to download it from the website and run the self extracting EXE
This then put the installer on my HD - of course the installer didn't install any software, since I had it already, but the installer folder was then what the Additional Installers was looking for when doing my build.
Gah - very annoying.
Message 6 of 9
(4,009 Views)
Yes that is what I ended up downloading.
Message 7 of 9
(4,006 Views)
Just out of curiosity.  And so if it ever happens to me......
Which LabVIEW 2012 Installer disc has System Configuration 5.3.3 and what insane jibberish did NI use?
Message 8 of 9
(4,002 Views)
I never did find out which disc had that installer on it.  I downloaded it from the website. 😕
Message 9 of 9
(3,928 Views)
