Which LabVIEW 2012 Installer disc has System Configuration 5.3.3 on it?
I am trying to build an installer here and under additional installers I selected to install MAX 5.3.3 - the installer builder is asking me to locate the installer for System Configuration 5.3.3 but I can not locate the source installer.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
Message 1 of 9
(3,447 Views)
Device Drivers\Products\MAX\max.msi
Message 2 of 9
(3,443 Views)
Hmm
I am told to locate "NI System Configuration 5.3.3" and when I supply the path to x:\Products\MAX I am told:
"This location does not contain a valid installer"
This process is very annoying!
Message 3 of 9
(3,436 Views)
There are also some folders names starting with NISysCfg in Device Drivers\Products\.  Have you tried these?
Message 4 of 9
(3,427 Views)
download is here
 Sorry I took you in the wrong location
Message 5 of 9
(3,416 Views)
Accepted by RVallieu
I had to download it from the website and run the self extracting EXE
This then put the installer on my HD - of course the installer didn't install any software, since I had it already, but the installer folder was then what the Additional Installers was looking for when doing my build.
Gah - very annoying.
Message 6 of 9
(3,408 Views)
Yes that is what I ended up downloading.
Message 7 of 9
(3,405 Views)
Just out of curiosity.  And so if it ever happens to me......
Which LabVIEW 2012 Installer disc has System Configuration 5.3.3 and what insane jibberish did NI use?
Message 8 of 9
(3,401 Views)
I never did find out which disc had that installer on it.  I downloaded it from the website. 😕
Message 9 of 9
(3,327 Views)
