How to make a decoration not clickable?
I need to put a decoration over a button, but decoration blocks button's hitbox. Is there a way to solve that?
(4,863 Views)
We're going to need a bit more information... but a place you might want to start is looking at the Z-order
https://www.ni.com/docs/en-US/bundle/labview/page/setting-the-tabbing-order-of-front-panel-objects.h...
Edit:  To clarify, by "more information" I mean what are you trying to do?  I can't think of a good reason to place a decoration OVER a button - which means there is likely a better way to accomplish your goal.  Please post your code or the VI you are working on.
(4,853 Views)
Most of the time, a decoration is placed over a control in order to do just that, prevent interaction.  If you are wanting to change the icon on a button, right click the control, click Advanced -> Customize.  This will let you add decoration that is part of the button and doesn't interfere with its operation.
aputman
(4,833 Views)
Do you want to customize control (is that you wanted to achieve?)
If Yes you can customize and save as a control file.
(4,797 Views)
I often use decoration on my Front Panel, like a piping diagram to aid the GUI. In such case after placing the png picture on the FP, I need to bring other "active" LV components to front for example...
Select your button or other object. Go to "Reorder" --> Move To Front:
edit: when you place a decoration on the top of your existing button, obviously just select your decoration itself, and click on "Move To Back"...
(4,784 Views)
I want to customize my buttons thats why Im putting an object over a button, I didnt share the vi because I thought it was a just a general question, I couldn't do it with Advanced -> Customize tooButtonIcon.png
(4,746 Views)
Accepted by aaa_aaa
[video]
A Jing is worth at least 1000 words
(4,743 Views)
