How to make a graph that plots "steps"
Hello I want to be able to plot a graph that displays "steps"
I am using the Plot Waveform.vi still went I change the waveform plot type to squares (which I think is the control to change) nothing happens.
Please see the attached pic of what I am getting right now, thanks
 I will also like to change the x axis to display 0 to 10 instead of -100 to 0, I have tried changing the minimum and maximum values for x from the cartesian axis attributes, but then the graph goes out of range.
LabVIEW Intermediate I level!
Message 1 of 22
(4,147 Views)
you can right click the plot legend and from there you can change your plot to what you want
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 22
(4,141 Views)
Do you mean a bar plot?
That creates a picture plot. Is there a particular reason you're using a picture plot as opposed to a regular graph/chart? Also, that setting changes the plot point itself, not the graph type. In other words, that setting means that each point is drawn as a square, which is what your picture shows.
Then you need to change the data. Your data clearly shows X values in the range of -80 to -20. Obviously, if you change the X range to 0 to 10 the graph will go out of range. How can the plot show points that are not in the range you've specified?
Message 3 of 22
(4,133 Views)
do you mean on the Front panel?
I have attached the VI for a better understanding
Message 4 of 22
(4,130 Views)
Hello Smercurio,
For the data range I understand what you are saying, How can I do then to "fix" the values on the x axis to display something else. What I mean is to have the data as it is but display something else, like have the -100 be equal to zero, the -90 = 1, -80 = 2 and so forth?
and for the reason I am using this picture plot is because this is legacy Software and I am making some modifications to it, but if you can give me suggestions I will really appreciate them.
and for the way that I want it to be plot or graph is to be seen as stairs
Message 5 of 22
(4,124 Views)
Hello Smercurio,
This is what I get from the bar plot (see attached),  I will like to have it kind of like that but with the bars below, inverse.
Message 6 of 22
(4,114 Views)
It looks like you selected the wrong 'Fill Base Line' option. To change your scale, you just have to specify an Offset.
Message 7 of 22
(4,096 Views)
Hello Dennis,
where do I go to change the "fill base line" option? thanks in advance
and for the offset is that in the cartesian axis attributes?
Message 8 of 22
(4,082 Views)
Hello Dennis,
Message 9 of 22
(4,081 Views)
There are a couple of ways. First is to use the help so that you learn how yourself. To change the fill, right click on the Plot Legend or right click on the graph and select Properties>Plots. To change the offset, go to the Scales tab.
Message 10 of 22
(4,078 Views)
