How to make a graph that plots "steps"
Accepted by Bebeto
To do what you want would require more extensive modifications of the subVIs, and that's not a recommended approach. I would, instead, suggest using the Plot XY VI rather than the Plot Waveform VI. You would basically just create a series of XY points which are connected together. Thus you can draw a more "step" picture. See attached example using your dataset.
Message 21 of 22
(601 Views)
Hello Smercurio,
Thanks for all your help, I made a few modifications to it and it is now displaying the correct graph.
Again thanks.
LabVIEW Intermediate I level!
Message 22 of 22
(584 Views)
