How to make a really basic alleyway for a beginner
Okay one strange thing happend when i pulled the vi back. The paddle y location starts at 0 and needs to be 600. So here is the same vi with that change made.
- A minute saved is a Minute earned!
Message 21 of 24
(933 Views)
Interesting. Some quick comments:
  1. Can you explain your reasoning going to EXT precision for some of your orange wires??? 😮
  2. Make the stop button latch action and the local variables and value property nodes of it are no longer needed.
  3. Value properties are probably the most inefficient way to share data between loops.
Message 22 of 24
(911 Views)
No need for orange wires. in fact i went back and used U8 and everything still worked. The c-style programming block gives me orange out and i couldn't figure out how to change it. So that is why they are orange. I put a convert to U8 after it now.
And yes i removed the property node to the stop button and fixed that part too 🙂 I wrote this back when i first started labview 2 years ago.
Message 23 of 24
(820 Views)
You need to declare your variable in the formula node.  If you have a line int32 degree; at the top, you get an I32 for the degree variable.  If you have uint32 degree;  you get a U32.  Both of which are blue integer type wires.
Message 24 of 24
(813 Views)
