How to make array from semikolon-separated text
i have a text with multiple lines. The lines are separated with \r\n.
In each line is the same number of values that are separated with semikolons ;
How can i (easy) make arrays of each value in a line?
Currently i solved it by creating a loop and using match-pattern, shift register, insert to array...... But this looks very big.
How can i make this easier?
Thanks for the help
(3,168 Views)
Hi OnlyOne,
you can use the "Spreadsheet String to Array" function.
Mike
(3,167 Views)
How do i use this?
Attached my current version (LV 8.2)
(3,163 Views)
Accepted by topic author OnlyOne
you have to define the seperator.
See the attached image.
Mike
(3,161 Views)
