How to make my front panel visible?
 My front panel got completely invisible when I made changes to an already existing program.(It is to be noted that when I resize the front panel controls in this particular program they get invisible too. strange!!). But I can see the block diagram.
Did anyone had this problem. How can I solve it.
Help please.
DSK
(4,120 Views)
Try putting this code in your block diagram.
This code gets a reference to the current vi and centers the front panel.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(4,093 Views)
If it is really invisible, you'll need this:
(4,089 Views)
HI,
  Thanks for your reply.
I want to know how to write  "x 2"  parameter in the "Open VI Reference" function, I couldn't do it.
What is it for?
Can you send me the code as an attachment so that I can directly copy into my program.
Thank you.
DSK
(4,077 Views)
Check out the help for the Open VI Reference Function.   Or, if you have the OpenG library, just use "Current VIs Reference".
VI is attached.
(4,064 Views)
The x 2 is really hexidecimal 2. you can right-click on integer numeric controls, indicators, and constants and select visible then radix. you can then use the radix to select how you want to view the integer data. When you create a constant from the Open VI Reference node, the radix is on and selected as hexidecimal.
Hope that this helps,
Bob.
(4,061 Views)
