Strain Gauge Bolts With cDAQ-9172
Hello Everyone,
I am using the cDAQ-9172 with NI 9237 connected to NI 9949.  I have some strain bolts that have a value of 2000u for 15.7 kN.  I was wondering what I should put in for gage factor?  Also what is an appropriate signal input range?  Thanks in advance for any help.
James
(2,364 Views)
James,
Those values depend on your particular strain gauge you're using. There should be a spec sheet for your particular gauge that will contain that info.
Kyle Hartley
Senior Embedded Software Engineer
(2,347 Views)
