How to make only one element as Indicator in cluster in Labview
Hi friends,
               In a cluster how to make only one element as indicator. For ex: I attached 1 file in that t want to make only 2 Boolean LED as indication & 2 strings as controls. How to do this.
Thanks & Regards,
Harish. G
(2,854 Views)
Accepted by topic author HarishG
A cluster is an indicator or a control.
However you can disable certain elements of your cluster control  by rigth click , advanced, enable state  or with a property node
I put together a small example
Greetings from Germany
Henrik
LV since v3.1
(2,850 Views)
HI Henrik_Volkers,
                     Thank u very much. It's working fine as i expected.
Thanks & Regards,
Harish. G.
(2,841 Views)
