How to make visible and invisble the 'Decal Image' programatically?
Hi All,
I do want to make invisible the decal images of boolean controls.
How I can do this programatically?
Is there any property node is available in scripting?
Thank you,
Yogesh Redemptor
Yogesh Redemptor
Message 1 of 15
(5,005 Views)
Hi Yogesh,
You can use the paintbrush tool in the Tools Palette to set colours of front panel objects. To open the tools palette navigate to "View -> Tools Palette". You can then use the paintbrush by selecting a colour and left clicking on the control you wish to change.
The screenshot attached shows how to set the current colour to transparent.
Many thanks,
Eden S
National Instruments UK & Ireland
Message 2 of 15
(4,995 Views)
Eden,
Yogesh wants to do this programmatically.
George Zou
Message 3 of 15
(4,972 Views)
You will need to "cheat" on this one since you can't Show/Hide the glyph at run time.  The simplest means would be to have two buttons one with the glyph one without one off screen and swap their positions when you want to change appearance.  Handle both value change events in the same case.
Message 4 of 15
(4,961 Views)
Edit - Jeff's answer was better than mine.
Bill
CLD
(Mid-Level minion.)
Message 5 of 15
(4,960 Views)
Could you also have them in the same place and hide/show them as needed?  All you need then is a boolean and its NOT to control the show/hide properties?
Bill
CLD
(Mid-Level minion.)
Message 6 of 15
(4,955 Views)
Yes, that wouls be what I would recommend.
 Yet another alternative is to make your button transparent and place a picture control under it. You can then change the picture to whatever you want and you have a single button to manage in terms of the events.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 7 of 15
(4,945 Views)
Show hide might have some trouble dropping through the top one to hit the bottom when the top is hidden .)
Message 8 of 15
(4,940 Views)
Personally I like to use invisible Tab controls instead of futzing with positions and visibility.
Message 9 of 15
(4,930 Views)
I just hate tabs. Especially when I might hands off refs to objects on tabs. Too many bad memory of refs going stale when the tab changed. Maybe that's better now but, I still avoid them.
Message 10 of 15
(4,922 Views)
