How to make visible and invisble the 'Decal Image' programatically?
@JÞB wrote:
Show hide might have some trouble dropping through the top one to hit the bottom when the top is hidden .)
It works fine. I have used it many times. Stacked buttons work quite well. The hardest part is lining them al up so the transition is smooth. If the alignment is off you can see the switch.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 15
(1,624 Views)
Alternatively, you can hide the decal behind the button.
George Zou
Message 12 of 15
(1,618 Views)
This is the hidden property 'Decal Scaling'. I have not seen this before.
Unfortunately it is not helping me because, I am using system boolean buttons with decal image/icon.
Is there any other hidden properties are there wrt 'Decal'.
I have created the UI's with decal images in my project; I have asked to remove all decal images because of licensing issue.
I am looking any simple method instead of opening every UI's + different tabs and doing manual change.
I hope NI will have some option for this. And keep opening other possibilities!
Regarding,
Yogesh Redemptor
Yogesh Redemptor
Message 13 of 15
(1,574 Views)
i did this awhile back w button controls, sounds similiar to what you are discussing here,maybe not..
Message 14 of 15
(1,567 Views)
Add:
SuperPrivateScriptingFeatureVisible=True
to your LabVIEW.ini
You'll see the hiden scripting property.
George Zou
Message 15 of 15
(1,545 Views)
