How to manage many files?
I'm using IMAQ USB to generate a snap shots every 10 seconds by using two USB cameras. After the program takes the snap shots, it saves the pictures in a folder. I usually run the program for a day. After a day, I generate about 17,000 22kb JPG files.  When I click on the folder to view the files, I often have to wait 30 seconds or more for the folder to open, and the system begins to run extremely slow after that.
Is there a certain way to manage many files?  Can I do something to my program to prevent this from happening?
By the way, I'm running a 3.2 GHz P4 with 512mb of ram.
Any help will be appreciated.
Thank You,
Molana
(2,769 Views)
The problem is the 17K worth of files in one directory. One method would be to have your code create a new folder every hour, possibly naming the directory with the date and hour, then you will end up with 24 folders with 360 files per folder. I use something similar on projects that are going to run for a very long time, that save files less frequently than yours, but once every few minutes for 6 months works out to a lot of files too!
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,762 Views)
Thank You. I'll give it a try.
Molana
(2,758 Views)
You could also save the images in a database--would make them easier to find too...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,749 Views)
