06-21-2010 01:25 PM
i need to measure frequency from a tachometer (counter input) and voltage (analog input) by simultaneously by USB-6229 M series DAQ board and labview 2009 .i am able to get each of them separately .but how can i get both of them at the same time?
06-22-2010 11:15 AM
Hi s-p,
Here is an example that will probably help you get your application started. Post back if you have questions!
