faster data communication way
I am using RT system. I have tried with shared variabe to output a signal(Double) to another RT system. It takes about 100ms. It is obviously too slow to my required frequency. Is there a faster way to transfer data? Thanks in advance.
Message 1 of 10
(3,944 Views)
Hi Guo,
you can use TCP/IP for it.
The example finder will give some starting points.
Mike
Message 2 of 10
(3,927 Views)
Shared Variables should be much faster than that.
Read this document to learn more.
http://zone.ni.com/devzone/cda/tut/p/id/4679#toc4
Message 3 of 10
(3,904 Views)
hi sachsm,
your answer is quite inspired. But in that case I should output the signal I have just one while loop to acquire image and do some analysis. I don't know how to add a single process variable to pass the data to a network published varible. It meas how to establish the high priority loop and low priority loop.
Message 4 of 10
(3,886 Views)
You can use Timed Loop's which have a loop rate and priority setting.   Perhaps you can describe your application in more detail or attach vi's so I can offer more help.
Message 5 of 10
(3,882 Views)
This is the image. This loop is under a case structure.
Message 6 of 10
(3,865 Views)
Do NOT post bmp files renamed to jpg just to get around the ban on them. Do you really think that saimply renaming a file changes the file format?
Message 7 of 10
(3,847 Views)
I think that the problem is that you are trying to use single point data transfer via NSV's, you need to add buffering to the NSV's.
Message 8 of 10
(3,837 Views)
I have tried with multi-buffer. It worked slower.
Message 9 of 10
(3,822 Views)
Could you show me the client vi's?  Aggregate NSV data transfers via the PSP (Publish Subscribe Protocol) on a 10ms interval.  You can use the Flush vi to force
any pending NSV data to immediately transmit.  Also, could you tell me what type of NSV buffering you were using?
Message 10 of 10
(3,813 Views)
