How to measure on time and off time in waveform chart
Hi
I have some doubt of measuring on and off time in waveform chart by using array. But I cant find solution for it
So can anyone give me some example for it
(2,871 Views)
What do you mean by on time and off time?
If you have some boolean value, a simple solution would be to use the Boolean To (0,1) Function to convert to a number and then plot those values.
GCentral
(2,862 Views)
Hi Balaji,
Do you want to do something like this?
(2,860 Views)
Thanks for the reply Wat I need is total time period of the waveform form starting point to stopping point.
(2,814 Views)
Try the Waveform Duration VI.
If that's not what you're looking for, perhaps you could post your code?
GCentral
(2,811 Views)
