How to monitor USB ports?
I want to monitor USB port for insert & Removing of mass storage media or daq card and also want to monitor DVD drive. Please help me..
Thanks in advance
(4,415 Views)
Hello Devaseelan,
        If you want to receive a message when the USB has been plugged in or off, you can use the "wndproc" windows procedure (http://msdn.microsoft.com/en-us/library/ms632593.aspx)
      If the implementation is through .Net, you can override this wndproc process, but when it comes to LabVIEW  my recommendation is to implement it through  Windows Message Queue Library
AshwiN,
(4,384 Views)
If you use the Windows Message Queue Library as suggested (and I agree it's probably the easiest way to do it), you'll want to listen to the WM_DEVICECHANGE event. The readme contained within the archive lists the values for the various messages.
(4,360 Views)
