non-sequential numeric input
What is the best control to use when the input choices are not sequential?
For example, 0-2, 10-12, 40-42, 100-102, etc.
I was thinking on using a Text Ring or a Menu Ring.
(3,014 Views)
Accepted by topic author nyc_(is_out_of_here)
Either one will work. The functionality is basically the same, but the look of the control is different, so it depends on whether this is the front panel of a top-level UI or a subVI. On a UI the menu ring looks like a "regular" control, whereas the text ring doesn't.
(3,002 Views)
