How to move terminals around on a subVI icon
SOLVED
queue_ball
Member
I'm creating a library of subVIs for a working group, and the terminals need to be arranged more rationally than they come out when I simply create the subVI.  Is there a way to move the terminals around?
7 REPLIES 7
OEM_Dev
Member
Re: How to move terminals around on a subVI icon
hold ctrl while clicking on them allows you to swap two terminals
Gregory
Trusted Enthusiast
Click the first of two terminals that you wish to swap. Hold control while clicking the second terminal you wish you swap. You can swap with blank terminals as well.
queue_ball
Member
When I finally found where to do that (left icon, upper right-hand corner of Front Panel window), it worked beautifully.  Thanks much.  Brent
altenbach
Knight of NI
Of course you need to watch out if you also leave the subVI in the code where you created it. Swaping connectors on the connector pane will NOT swap the connected wires in the calling VI. You need to be very careful, especially if several terminals are of the same datatype.
billko
Proven Zealot
Hope for broken arrows in every VI that uses this subVI, otherwise you may not catch all the mistakes as LabVIEW tries to guess where the old wires are supposed to go.  What I do, if at all possible, is to actually change the pattern to something similar, then make the change.  Then all the VIs that use this subVI have broken arrows because they will all complain about needing to be re-linked.  Re-link them and check them as you go.  If needed, you can always re-choose the original pattern and re-re-link them.
Bill
CLD
(Mid-Level minion.)
tst
Knight of NI Knight of NI
Knight of NI
Remember that this only applies to callers which are actually loaded when you make this change. If the VI you're changing might be called by other VIs, which are not loaded, you should be aware of that and take appropriate steps (like loading those VIs before modification, or not doing the modification or having unit tests to see that they still work).
___________________
Try to take over the world!
billko
Proven Zealot
True.  I forgot that step because I do that so automatically.  Thanks for fixing my suggestion.  Smiley Happy
Bill
CLD
(Mid-Level minion.)
