How to open and save pictures from 1 folder at the same time?
Is there a way to open and save pictures from 1 folder at the same time?
I'm creating a vi that resizes the picture but I want to do it with 1 folder at a time... Is this possible?
greetings!
(3,049 Views)
Use a file dialog to select a folder, then use "list folder" with your desired pattern (e.g. *.jpg). You get an array of all matching file names. Feed it into an autoindexing FOR loop to process all files.
Make sure you don't accidentally "process" and non-image files ;).
(3,045 Views)
Hi Kway,
Here you are. I wrote a file a customer times ago & It did what you want! Smiley Wink
Just see the attachements and keep me inform.
Julien Roland - District Sales Manager
NI Belgium - Technical Support
Don't forget to rate a good answer
(3,022 Views)
I tried to open it but I don't have LV8.2 :s (I just have LV8.0)
(3,012 Views)
Here you are. I saved the files in version 8.0 of LabVIEW Smiley Happy
(2,996 Views)
